Hi, if you have Arc S
Then refer here
Software updates are released at different times depending on operator and country. Therefore, we cannot give you an exact date for when a specific update will be available for your phone.
If you have any other device then -
Xperia arc, Xperia PLAY, Xperia neo, Xperia mini, Xperia mini pro, Xperia pro, Xperia active and Sony Ericsson Live with Walkman will receive their scoop starting from the end of May/early June.*
Then refer here
thx for the quick answer
