we all know that when we Drag the status bar downwards
in all android phones (Notification panel)
we find the bluetooth wifi and sound
my xperia acro s there is no any of this only the settings and update available
can any one tell me what can i do !
thanks
if you unlock your bootloader to flash a custom ROM you are not going to be able to use PCC or SUS or Bridge, your DRM keys will be gone and you can't restore them. There are apps and/or services that will stop working. Check the XDA forum
i am sad
i dont know any thing
this is a screen shot (about device )
hope you can tell me is that stock or custom rom
http://postimg.org/image/vwrwv3735/
i wait your reply
As far as I can see,it is standard ROM from sony.
will i know if i download root checker or this another thing !
I agree with Alexdon
Even if you are rooted and PCC or SUS fails to update saying "Modified software detected" then you can use Sonys developer flashing or update software called Emma found here http://developer.sonymobile.com/2012/12/06/new-flash-tool-from-sony-for-unlocked-xperia-smartphones-...
