hi
1-when my phone goes to stand by , after a while it comes out automatically and the screen stays on unti I set it to stand by manually , and then the same thing happens again ...
2-I can't update my phone.
help pleeeeeeeease !
tnx
Hi, possibly a software repair will fix your issue (seems to be a software glitch). Here's the download link to Update Service, http://www.sonymobile.com/gb/tools/update-service/.
Download and install to PC/Laptop, launch it and follow on-screen instructions. Be aware that this will erase phone data completely, backup if necessary.
Thank you very much !
No problem.
