Hy, i broke the screen of x10,how do esport all data ? TTOUCH is not working,the screen is black but the phone is turned on,Pc companion can not connect,can anyone help ?
thanks for help
you could try something else but you need a pc or you could try and see if it work with your tablet
go to
play.google.com > sign in > look for my phone explorer, install my phone explorer on your tablet/pc
its a long shot but it might work
ok, you have to replace the touchscreen/digitizer and the LCD, you could take it to a Sony repair center or repair it yourself, the later its a LOT cheaper and its not that complicated, trust me, I've replaced the digitizer on my old X10
this is how to disassemble your X10
http://forum.xda-developers.com/showpost.php?p=6368979&postcount=82
as for the parts check ebay
ok very thanks for help (from italy ).
But soon i will have a new xperia,my problem is to recover the data (contact and image ) from x10 broken,without addressing cost of repair (after retrieving all data x10 scrap )
you can use PC Companion to get all your contacts, if you already synced with google then on your computer access your gmail > contacts
as for your pictures, music, videos they should be stored on your SD card.
hy, i connect x10 via usb, pc companion detcts phone,but for connect x10 with pc via companion x10 requires press " connect phone " into Ttouch but Ttouch is k.o with screen
and i don't have my contact in gmail
try this
I don't have my X10 with me at this instant but
remove the SD card > then connect your phone to your PC
already taken,i'm sorry if i make you waste time
have you checked your gmail (on your PC)?
