I want to buy Philips SHE7050BK/00 CitiScape Indies, while the old Earphones that came with the mobile don't work. will it work on Xperia S ?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
As there seems to be no mic involved, yes these should work just fine.
If there is a mic on the headphones (headset), it must follow the same standard as the phone. See this topic for more information.
http://talk.sonymobile.com/t5/FAQ/Problem-using-headset-accessory-not-supported/m-p/347872#U347872
Thanks !! :smileysmileywink:
