Hi
I bought xperia sp yesterday and when connecting to the wifi, it says "limited access". I have 4.1 Jelly Bean. But, my SP connects with wifi hotspot of my other mobile and works fine. Help please.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you take a look in our FAQ-topic regarding Wi-Fi. You can find it at the following link:
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104
Hey!! Thanks a lot!! There was some fault in my router. Did a reset, and it is all fine now. Thanks!!:smileyhappy:
Good to hear that you solved it. :smileysmileythumbsup:
