Hi, I have made a Backup with the new Backup and Restore tool from ICS. The backup is saved in the internal SD-Card (internal Storage). But I cannot find the Backupfile on the Phone. I have tried the Windows Explorer and the ES-Filebrowser on the Phone. Does anybody know where the File is saved or where i can find it ???
Try in the recovery folder on the sd.
The Recovery folder is empty !?!
Try sd-Android-data and search there.
.... nothing
Does anyone from the Supperters know where the File is ????
Are you sure you did backup?Search on sd card,scrolling down down after all folders,my juice defender backed up data and put it there.
I Have maked a Backup, and I can make a restore From the SD-Card. I have used the new Backup and Restore Tool wich is included now in ICS for SXP.
The Backup-File is shown in the Tool with about 4.1 MB huge. The Restorefile is 2012-09-07-114329.
I search now about 3 days for this File, have used various File Manager and Explorers...
The tool doesn't show where is the file located?Or maybe is within the application.
Ok.do not forget to set the question answered,if you want.You are welcome.
