I'm having a bit of weird problem with my Sony Xperia Sola, after having connected the device to PC in order to be charged, a series of digits appeared on top of the screen which cannot be removed, these appear to be coordinates of the screen for some reason:
P:0/1 dX:3.0 dY: - 5.0 Yv: 0.0034 Size: 0.18
Furthermore, the touchscreen shows tracks of the finger movement in the shape of 2-dimensional axis, exhibited on the pictures attached to this announcement. It might be that I have accidentally switched on a setting/application. I just have no idea.
Would you be kind enough to help me?
Thanks in advance Best regards
Damon Amin
settings > developers > uncheck the options
Thnxx, mate! As I expected, silliness on my part & I really appreciate your help
it happens, Anytime
