I need help over here
when i make a call and finish it and i get a msg with my current credit left and it appears in a very wired thing , so please anyone help me
Here is a screenshot:
Sounds like some encoding problem rather than language problem. SMS should be in english ? What language / region is your sola set to ?
You should contact you phone provider, as they're the ones sending that SMS. What app is that doing the pop up ?
Fixed, Thanks alot ❤️
