When I access the Daily Mirror or Guardian websites via the Android Web Browser I get the HTML code appear. Anyone else get this or is this something with just my phone?
I checked my client ID and it says: Mozilla/5.0 (Linux; U; Android 2.3.7; en-gb; SonyEricssonST25i Build/6.0.B.1.564)AppleWebKit/533.1(KHTML, like Gecko) Version/4.0 Mobile Safari/533.1
Same here with Xperia Ion...
Seems the sites are not optimized for android browsers...
I have Opera mobile (Free in Play Store) installed and it works fine for both sites. (Mirror and Guardian)
Hope this helps
Francis.
Thank you.
I have Opera installed and they work fine in that. I didn't have this issue on other 2.3.7 Android phones so maybe Sony need to look at changing the client ID. It may well be a issue with the CMS the websites use but only on Sony phones.
