Hello, after i cleaned my Xperia Go at sink, i discovered later that there's water under back cover and all the blue part is wet.
I examined the cover and possible holes and i saw that the hole where you put rope (bottom right corner), there can water come in.
Is it normal that there is water under my back cover, can it break my phone?
When i clean my phone i allways make sure that Headphones and USB holes are closed.
It's OK to have water inside the back cover (the one you referred to as blue part) and the rope, just do not allow water inside the USB and the headphone/headset jack. Have it tightly closed so as not to damage the device.
HTH
Discovered also that from headphone hole (on cover) comes water in.
