use the mediago software to manage songs. its much easier that way
Are you sure the songs are not at the bottom "unknown" ? you can also try this
settings > apps > all > walkman > clear everything > restart your phone
Don't forget to give Kudos
In some cases a reboot of the phone will be needed if you have added a lot of media data to the phone.
What are your thoughts about this forum? Let us know by doing this short survey.
Reboot by pressing power button+volume up until the phone vibrates one time(forced restart).Also,delete LOST.DIR folder in internal memory.
Be careful because you have 2 walkman apps in settings-apps-all.Clear data for both,delete LOST.DIR and see again.If not,repair phone software with sony update service.
