i have a w350 and the camera will not save a picture. when you take a picture, it goes right back to the icon menu. it will also not show any pictures in texts now either. HELP!
Mike
http://www.sonyericsson.com/cws/support/softwaredownloads/w350i?cc=gb&lc=en I suggest you run the update service on your phone and/or perform a phone repair via PC suite.You can download all this software from the above link.
THANKS! All fixed!
No worries!
