Hi guys. I've got a problem. When I applied new theme from sony select at first i thought everything was okay. But then when i tried to increase and decrease the volume of my device the volume bar on the upper mid of my device was gone. There's only a black bar appearing. I tried changing my theme to the pre-installed theme and rebooted my phone but it is still not there. What should i do? Hope you can help me with this. Thank you guys in advance
This can be found on the SP also,it seems only with default theme works fine for now.
I have the same problem with my xperia V also so how do you fix the issue? Need help please.:smileyconfused:
Anytime.
that woody theme **bleep** I had this problem too wont install that again. Sony, please design your own
