Hi, I just actualied my xperi p, and every seems to work ok, exept that i can send/recive mails form other accounts taht are not gmail, and before the actualization, I have no problem.
Also there is a message that apears every time i try to use the mail " mail has stop, accept",
can you help me?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
First of all I suggest that you clear data for email under settings > apps > all > email > clear data. Restart your phone and try to configure your email accounts in the email application again.
