hello guys,
I want to know if xperia sp support video calling?i could not find option for video call anywhere in phone.
yes it does but you need a data plan, you can use Gtalk/Hangouts or skype or tango, it does NOT support native video call, android doesn't support this feature natively, some android phones do have this, but it was added by the OEM in certain phones on specific regions/countries. This has been requested by users for many years most likely it is NOT going to be added
@hanie that you say mostly like that your network connection speed is low
can you use video call in other apps like tango or skype?
