Dear Forum colleagues
After getting Xperia SP I installed Viber app.
Unfortunately when I tried to send out a message (SMS) I selected to use Viber for always and not for just that time. Now I cannot use other way because Viber automatically appears when I start writing down a message,
Tried to uninstall and reinstall but the problem persists. Final solution was to remove Viber from my mobile.
Is there a way to fix this problem having back the possibility to choose each time what would be the option to be used like Viber, SMS or skype message?
Many thanks
