Is there anyway of anti-tethering ,,,,,i want to use pc internet on cell phone...is there any application or method...i know it is available on rooted oses i.e cm9 etc....
There is no way of reverse tethering besides rooting and using apps that allows you to do so
Are you saying that you have no wireless signal at home? If that's the case, the only way to reverse tether involves rooting the Xperia and running an app - there's no USB reverse tethering on these phones.
Bearing in mind that rooting will invalidate your warranty - and that using wifi is often the fastest, cheapest way to use data on phones as well as being generally very useful for other devices (not just PCs and laptops - more and more TVs, blu ray players etc are using wifi) - it might be easiest and best just to buy a router with built-in wifi.
Just root your device and use the app 'Reverse tether'
Yes, you could actually, if your using windows 7 you can use your PC as a HOTSPOT , just try CONNECTIFY or virtual wifi router.. this works even without router.
oh, you talkin about USB teethering? ha, yup, you need to root and find a reverse tethering app for that,, sorry
yeah i know that and ill root my phone when warranty will be over
