hi,
I'm new on the forum, and failed to find an easy way to navigate through it, looking if someone had dropped the question already.
My question is:
I used to have a Sony walkman phone where one easily could address the music.
One of the features on that phone was that, when pressing the volume button up/down for about 2 seconds, the next/previous track of the music player was selected. This way it was possible to easily navigate through the music, without having to activate the screen and pressing additional keys.
This option is not available on my xperia ray and I was wondering whether this functionality could be added, whenever it is available.
thx in advance for the reply.
rgds, peer
have you tried to use the headphones? if you press the button once you will Play/Stop the music, press it twice and you will skip to the next song, press it thrice and you will go back to the previous track
Unfortunately at this stage I am unable to advise if such an update would occur, however you may be able to find a application from the Play Store that may provide such a function.
once you get Android 4.0, you can change the tracks from the lockscreen or if you don't want to wait that long check this options
WidgetLocker
ICS Lockscreen HD
Lucent Lock Screen
Extended Controls
Don't forget to check if your SI number is on the list
http://talk.sonymobile.com/message/199350#199350
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
also if you don't want to wait for the update, you can manually update your phone
1st backup your current firmware
2nd manually update
this is how
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
