No, you can use your PC's explorer
Computer > Xperia SP > internal storage/SD card > copy/paste folders, files, etc
In this case,enable MTP and see if you are prompted to install drivers (MSC should have worked though). Also,check this out:
http://talk.sonymobile.com/t5/FAQ/USB-connection-problems/m-p/348074#U348074
