Hi ,
I have an axperia t3 and today when i wanted to plug my earphones my phone just shut down. After this it keeps restarting and to do anything on the phone beforeit restarts i have like 10 seconds ... Because opf this short time pc cant find it. restarting it while holding pover and volume up button doesnt help ... What should i do ?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
Remove the SIM and microSD,see if it still restarts.
Awesome!
