sometime when i connect my mobile with pc in MSC (mass storage mod) ,all applications and games which was stored in SD card goes at the last of the menu page ( not every time but some time ) so every time i need to arrenge all apps again .....as shows below pics...
i m totally frustrated with this problem.
when i tethered my mobile to use internet battery doesn't charge . but my mobile shows battery is charging .this time i tethered my mobile frm half an hour but my battery is still 35%.(initially 36%)
this que is quiet diffrent frm above but i do not want to make new topic..so....i just installed pc companian which said that an update available for ur mobile frm 4.0.2.A.0.42 to 4.0.2.A.0.62 ( Update for what??? which type of update is this ????) and when i m trying to update it fails every time. can i update frm mobile ??
I've actually seen this problem before and as I understand effected app's are those on SD. I have reported this earlier but I will forward it again, but I think that we'll have to wait and see. Hopefully this will be fixed in the ICS update.
above image is 4th page and these are last two pages ,my all apps frm 4th and 5th page goes at last two pages......:smileyshocked: and not all SD apps goes but some apps (at first picture UC Browser , whatsapp ,and both games are in SD card.
thanx for replying i hope they make it.
but still i have one que...about tethered connection that i asked before, it this effects if we use USB cable of any other brand. actually yesterday i used my previous LG's phone cable and it doesn't charge my phone in tethered connection(but connection works well) and now when i use SE cable everything is ok :smileyblush:
just want to know ..:smileygrin:
