Hello,
When will the update for the Xperia Neo?
It stands on the site in October but I would like to know the date!
Gr. Jeffry
theres no particular date for any market or location..
you just have to wait for the update to arrive in your country..or you can manually update..
How do i do the manually update?
wait for it..
i have manually updated my arc..
and the same way you have to update neo but wth different files..
just keep a look at this thread..
for now dont try that method..
when i'll say then only perform the update manually ok..
