Hi
i installed update service software for update my xperia sp
but i didnt find xperia SP on update service !
what should i do ? help please
and what is difference between pc companion and update service ?
sorry for my english :):
It should check the phone,you can select for which model you want to repair or update.
Pc companion is not as good as update service,because the first is more of a file explorer combined with an update engine,but updates come buggier through PCC.SUS is an update engine only for update and repair,which gives better performance than PCC.
the problem is that SUS doesn't check for find my phone !!!
and i also enable USB Debugging mode but cant solve problem
and in the list of Phones in this software i cant find xperia SP !!!
thanks
pc companion worked correctly
i updated my device
You are welcome.
