I want to update xperia t.
With build number 9.1.A.1.141
But sus say your phone already has the latest software..what can I do?
By the way..Iran un branded
"You can find out which country is for your firmware by searching your Customization Number.
You must enter in the Service Menu by pressing "*#*#7378423#*#*" (*#*#SERVICE#*#*) in the phone dialer, and after tapping "Service Info" - "Software Info".
After that, you can download from this topic: http://forum.xda-developers.com/show....php?t=2608983 "Xperia update Checker".
With that software, you can check the last firmware for a specified Customization number, but also check which country and which carrier your firmware is for!"
they answerd me with this and figured out that phone is from UK
Chill danial,the update will come.But as you know,up to carrier/country to approve update.You could contact xperia care also for some info:
http://www.sonymobile.com/global-en/support/contact-us/
I know Alex...but i see Iran unbranded in your update availability topic...that why i'm curious about..
Well,"my topic" was updated according to the feedback I got.You should contact xperia care,maybe they can tell you more.
Ok
But no way to contact Sony on that page!!neither mail nor live chat..I got nothing!!how I can find out 9.2.A.1.199 is comes out directly after 9.1.A.1.141 or any firmware update were in middle?
I suggest you contact one of the sony support members.
Ok will do it..
But i find out that 7firmware certificated and rolled out after what I have!
Wow,that is something.Do contact them and after that we will see.
I will feedback here when they answered me
