Hi all
i have xperia arc x12
and i have 2.3.3. android
before few days i got notification NEW SYSTEM UPDATE AVAILABLE
but i DONT WANNA update my phone
how i can remove that notification?
thanks all i update my phone and notification is gone
its work\thx
To remove Update notification: just go to settings/apps/all/ scroll to update center and remove the click from notification box. No more notifications from any software update. You have to do it all manually or enabel it back. It worked on Xperia z3 compact.
Have funn.
