every time i try and update i get this message "nstallation failure. It's unable to install components OR to start the phone update" ive tried to reinstall the appilcation on my pc but no luck. i have also gone through some of the other feed on the fourm but i still get the same issue. any one help ?
try this instead
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
try this instead
Also turn off your firewall and/or antivirus then run SUS (make sure to restart your PC after you installed SUS)
if that doesn't work then
restart your PC -> F8 -> safe mode -> run SUS
Also
update/reinstall/install java
http://www.java.com/winoffline_installer
thanks dude, it worked like a charm, sweet, thanks!!!!
