hello, when tyr to update to 12.1.A.1.205 my Xperia SP,Sony PC companion giving an error. error in the attachment. how i fix this?
image: not found available update for your device
i set the pc companion in english and update process was successfully ended. tahnk you so much
Strange,I just wanted to understand what error you get.But glad it is sorted out.
and my old ticket solved by this update
http://talk.sonymobile.com/t5/Xperia-SP/cach-memory-clean-problem/m-p/713165#U713165
can you please post screenshot and tell us if bugs are fixed (any). and your overall response in improvement of performance !! :smileysmileythumbsup:
I had this bug yesterday when the firmware .205 has come, i think the servers were saturated
Hi there. I set my PC Companion to english but still had the same error. Any suggestions?
i have the same problem... an error occured during the update... it happened twice.. so I tried to disconnect and reconnect to retry the update... but worst is.. after the second error... i cannot turn on my phone.... i already tried the "Repair Phone" but the PC Companion cannot detect the phone unless its ON.... Any idea about this problem?
