I am trying to unlock bootloader of my xperia s. I am trying to follow the instructions here:
http://unlockbootloader.sonymobile.com/instructions
Everything is Ok till step 11. When I connect my phone to laptop (simultaneodusly holding volume up button), blue light turns on my phone for few seconds, then phone starts to charge. I am not asked for location of drivers.
I am using windows 8. Please help.
you need to press and hold volume down then connect the USB cable, it would help to run SUS or PCC on your computer before you do all that, are you aware of what will happen once you unlock the bootloader?
the DRM keys will be forever gone so your bravia engine wont work anymore, other apps wont work, you wont be able to update with SUS or PCC
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
Thanks Uli, I am planning to install cyanogenmod. Do I need to unlock bootloader?
yes you do, just remember that there are tradeoffs using a custom ROM
if you ever want to use SUS or PCC again
How to manually update 2012 Xperias to android 4.0.4 build number 6.1.A.2.45, 6.1.A.0.452, .53
http://talk.sonymobile.com/thread/41609
Thanks Again, volume down doest help either... I got blue light with volume up, with volume down, I dont get that either.
try this
repair your phone with SUS and then try again, that should get the correct drivers on your PC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
I had to unlock mine under Windows XP (32bit) as the drivers would not install under Windows 7 or Windows 8 (both 64bit) The phone went in to fastboot mode but only very briefly before moving on to mass storage or whatever it was.
Thing is it was a waste of time for me as i cannot root my phone as i need my banking app, so i have an unlocked bootloader and thanks to Barclays the standard .453 Sony ROM lol
