Hey guys,
I had bought a Xperia go phone 3months back. it was very smooth and fine in the first month. but now i have problems with the touchscreen. the part of the touchscreen doesnt work especially the left corner because of which i am not able to receive calls too. the middle of the screen the touch is perfect. I havent flashed neither rooted. Begnning i thought may be the phone is getting hanged but no. there is no problem as such. Could you please help me as to what i should do next?
repair your phone
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
repair your phone
Bridge (for Mac)
you mean give it to the service centre?
No, repair it with either PCC or SUS or Bridge, links above
@DSM if you have the same problem even after SUS or PCC, you should take it to a Sony repair center.
