Hi Sony
I have a problem with my touch screen... most of the time when i swipe between home screen it started to struck and move here and there automatically and certain part of the screen (1st notification item in the notification bar/ the google search widget in the home screen by default - (but i can move the widget and use it)/ video play button on portrait mode) not responding to my touch.....
I tried to repair it with the PC companion support zone but still the problem remain
Android version: 4.0.4
Build number: 6.1.A.2.50
Please someone help me...(i'm in Sri Lanka)
repair your phone with SUS or PCC if that doesn't work the it is a hardware issue
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
unrelated topic, if you have some time please check this thread
you don't have to create multiple threads
I don't quite understand, can you elaborate or post a video?
What i'm trying to say is only a part of my screen fail to respond (not always but mostly)
is it a software problem?
actually swap between screens not swipe sorry for the mistake
it'll be great if you could post a video. test your screen with this
I went to the service menu
I tried Touch screen in service tests
i drew narrow horizontal lines in the screen and the part of screen which i mentioned earlier not responding
i can send a screen shot but i don't know how to take it
Please help me
only horizontal lines are not possible.... vertically can draw lines
i don't understand what kind of problem is this
