Hello guys,
About a week ago I restarted the phone at which point it had a notification saying a certain process has stopped working. I wasn't paying enough attention and just dismissed it. However, I now find that my 'contacts' were gone and when I try to create a new contact, that would disappear aswell.
I tried both the 'Factory data reset' and 'Settings reset' but the problem remains, the contacts do not show up in the contact list even-though for texts the name would show up.
Has anyone experienced this or know how to fix this?
Thanks a lot!
Model: ST21i
Build number: 11.0.A.4.22
It appears you have a filter on your contacts. Please try this:
Main men u> Contacts > Menu Button > Filter > Uncheck all options under "Filter Contacts" > Check all options under "Contacts to Display" > Done.
What are your thoughts about this forum? Let us know by doing this short survey.
