I would like to know what do these notices mean on my text messages are, they sometimes appear like for example:
2SMS or +7 in a small black bubble
Its like a headsup that after 160 characters it will count as 2 text messages instead of 1, and it will be sent as MMS not SMS, also if you use special characters you will have less than 160 characters
That means you have gone over the maximum allowed characters per text message and are now deemed or will send said message a 2 and the 7 in this case is the amount of characters you have gone over the limit of 1 text message
Thanx! love your quote!!! 😃
Anytime
