Firmware: 6.1.1.B.1.54
I have 3G data enabled. I get the 3G/H symbol on notification bar.
If i try to tether wireless or USB , i get an error
Tethering Error
Error occured during tethering
I have reset the phone with full wipe.
I have repaired the phone using PC Companion.
But same problem persists. Please give me a solution to this.
Problem is when you have a XP from USA. And you are on a carrier other than T Mobile.
Solution is to flash generic firmware using flashtool.
does your carrier allow tethering?
Yes, im sure.
I have two friends who have same phone and same carrier, same data plan too.
try w/o a password
Tested it.
Does not solve the problem.
test with a different computer also do you have any taskillers or antivirus or background data traffic (on tethering)?
Why dont u update to.the new. 75 firmware. May be that would solve your issue.
Wont that void my warrenty?
If no, how do i do it?
I disables background data, no new apps installed.
Just finished reparing phone from a different computer.
Nothing.
