Good day
I would like to know how to set my phone (arc s) to use the phonepad keyboard and t9 (predictive text). I really am struggling to type messages and not sure how to set this.
Please help!
Thanks!
go to messaging > new message > start writing and you would see a pencil on the keyboard... tap it to turn the led green and thats it
hi
settings>language and keyboard> international keyboard> portrait keyboard > phonepad
for t9 > text input settings > word suggestions> use dictionary
Thanks for the help Nabeel
For the t9 section I have a problem though, because it's not giving me the option "use dictionary"
Here's the options I have under "Word Suggestions":
- Automatically correct words
- Substitute letters only
- Suggest Words, don't correct automatically (this is the option I currectly have)
- Don't use dictionary
I have tried all the other options too.
Any idea what i can do to get this to work? I'm going crazy if I type messages lol
Thanks Nabeel !
One more thing about the T9 using the phonepad keyboard.
How do I insert my own words?
I struggle to type when the word is not in the dictionary.
Thanks
Thats the demerit of T9 dictionary
you cannot write words outside it.
You need to tap on the pencil icon to disable it and then write your on words like hahahhah, oooooo,, okhhhh
:smileylaugh:..
