I have Xperia P (LT22i) with ICS (6.1.B.0.544).
How to stop vibrating while writing messages ?
I uncheck options in Sound > "Vibrate on touch" and "Vibrate on ring" and in Messing options "Nottification vibration" but it's still vibrate when I type/write messages (only in messaging)...
Please help...
open any message/sms > tap on the input box > once you do so an small keyboard icon will appear on the TOP left side of your phone > select input method > configure input methods > xperia keyboard > sound & vibration > vibration on keypress uncheck it
unrelated topic, if you have some time please check this thread
