My Xperia U is not playing sound notification messages. The sound settings enabled the sound to messages and notifications and configuration of message is also to play sound when new messages, most will not play anything. The Smarth the only one vibrated and nothing else, what can this be?
which messaging app are you using? or on which app you are not getting notifications?/
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
You can leave after both the xperia tweak could fix. Thank you for your attention.
:smileygrin:
did you figure it out?
