I have a Sony Blu-ray player connected to my Sony Bravia 3D TV. On the remote (RMT-B109P) , it has A Power 1 and Power 2 buttons.
They use to both work well at 1st but now only the small power button works n not the big button.
Is there a setting to set it somewhere to make them both work or not?
Hi there,
Hopefully a community member can help with this.
Best wishes,
M
Could you tell us more about the model numbers of each of them? There may be a specific setting to them, but the button may also be broken, try looking at it using your phone's front camera and see if there's a red light blinking at the pointer end of it.
