Hi Friends,
I am facing a problem of changing the Album art. It is taking the album art of some another snapped pictures. Can you please help me on the same how can i replace the new one and if I dont want to keep the Album art what is the procedure?
Thanks
Rahul
http://mediago.sony.com/enu/introduction/ You can use Media Go on your PC to remove and/or add album art/pics of your choice: Just right-click on the album thumbnail in Media Go, go to Properties--Art Work--Select to Add (a new window will appear for you to select a pic from your computer files) and/or Remove (click on the pic and then press Remove).After you've replaced the artwork, you can then transfer the album to your phone via USB cable: Right-click on the album--Add to--Memory card.
I think the easiest way would be to use any of the album art grabbers available on Market. Check if any of those might help.
https://market.android.com/search?q=album+art+grabber&so=1&c=apps
