After updating the telephone I synchronized my contacts list by using my Facebook contacts and by synchronizing my calender in outlok.
This resulted in a contact list with each item doubled up. Is there a smart & fast way of merging the two contacts with the same name into one ?
yes
just long press on the contact u want to join..
u'll see join contacts option..
when u'll click on that..the phone will give u recommendations..
if the 2 contacts u want to merge are there, just click on it..
Thanks for a quick and very helpful answer!
hmm
