Hi every tme I turn my phone on it tries to sync to sony them it tells me my info is wrong and go to account settings. I go into it and can't edit anything. Not that i know what to edit anyway. What account is this anyway? Help Very confused.
Just adding to it tells me that the server address is wrong just woundering if anyone can help out with this.
http://talk.sonyericsson.com/message/130201#130201
Discover how to switch to Google Sync Services today – either straight from your handset or via the web
| Thanks, | ||||
| The Sony Ericsson Team |
your alternatives
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Don't forget to mark the Correct & Helpful Answers
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Thanks so much. Should come on here more often. Read up on everything.
anytime
