Had LiveWare Manager updated to Smart Connect today. Now Smart Connect says it stopped and I was not able to launch it for a single time! I also lost Smart Tag functionality completely because Smart Connect would take over Smart Tag management. I tried to uninstall Smart Tag widget and switch NFC off but it did not help at all.
Sony, your app is corrupt. Any suggestions?
Thanks d10. I also found this update just before your response.
