Does the Xperia Sola have the new lock screen which lets users slide it to immediately open the camera app? And also, what version of Gingerbread is Sola running?
Sola has 2.3.7 and will get ICS sometime in late Q3, the feature that you mentioned its on ICS, but you can long press the shutter and it will trigger the camera w/o having to touch the screen at all
unrelated topic, if you have some time please check this thread
Is the Xperia Gingerbread 2.3.7 rom available for download? And is it compatible with 2011 Xperia phones? I am on ST17i but my Gingerbread version is 2.3.4 only.
I don't think it will work but you can try it
here are all the ftf files for the 2011 and 2012
How to manually update 2012 Xperias to android 4.0.4 build number 6.1.A.0.452
http://talk.sonymobile.com/thread/41609
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
Where is the Xperia Gingerbread 2.3.7 rom download? The ones you gave me are for ICS.
check again
Ah so it was at the middle most part, thanks!
Anytime
