I just bought an Xperia V and can´t even start it because the SIM card is too big. What to do? I thought there was a standard size for SIM cards.
it is NOT recommended that you trim/cut your SIM card, just get a brand NEW MICRO SIM card
Just order a Micro-Sim from your Carrier.
your phone only support micro SIM ,so you should cut it .
@qcpxf that's not a good idea, it might be too small or too big or he might cut on the wrong area and it might not have proper contact
what I mean is that you need to buy a SIM-cut tools,it cut the SIM in an appropriate size.I provide the picture of the tools :
I don't see the point on buying that if you can get a free micro SIM card from your carrier, unless they charge you a fee, but here in the USA are free
yeah ,if free ,you can ask them to cut the SIM for you .
why do you insist on keeping (cutting) an old SIM card, lol
your old SIM are breaken? if so ,you had better to buy a new one .
