I have upgraded to ICS, and it seems that this not not support separate volume control for notifications, i.e. this is now the same as the phone voulme control, which can be rather annoying having loud "beebs" whenever a mail, FB, etc. message is recieved.
Is there a was to set this on ICS?
there are many simillar threads to this.
http://talk.sonymobile.com/message/215695
the answer is no.
the answer is no.
Pity, thought going ICS would give more flexibility..not less!
Thanks for the reply.
