hi,
My Sony Ericsson vivaz phone has messages stuck in the outbox. It won't allow me to send Text Messages. I can recieve messages but because of the stuck message I cannot reply. I can't edit it or delete it from my outbox and it won't send either. I have tried reseting the phone and of course I have turned it off and on. Any Suggestions are Welcome. Thanks
I can onyl suggest performing a software update on the device using the Update Service, this should resolve the issue.
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Tnx sir ^^.....now i can happly use my sonyericsson vivaz fone ^^
Any time, glad I could be of help. :smileygrin:
