I am trying to install few android apps. But all are getting installed in my phone memory. Is there a way to change that setting so that it will be installed in SD card?
since you have android version 2.1 , and w8 will have no further updates , you cannot transfer apps to sd card...
this feature was brought in android version 2.2 and above android versions...
so thats why you cannot..
you can install a custom ROM , just go through the thread of walkman family and you will know all about custom roms...
Yeah i read few of them regarding custom ROM. But will it be safe and healthy if i do that??
Will performance remain same even after doing that?
performance :smileygrin:
many users said that its far better than se... you can check it yourself...
but yes warranty will be void so procceed at your own risk..
if you do everything right there shall be no problems
So diplomatic..:smileyconfused:
Ok i will try when got fed up with this phone...
yeah ok
It was actually brought in with Android 2.2, but apart from that you are right, Slim.
typo.. i will correct it..
