Hi and welcome @Scyther!
I'm not sure exactly how your selfie stick works but check if you can put it in pairing mode somehow and then scan for it in the phone Bluetooth options.
Check the manual for the selfie stick, I believe it should have a pairing mode.
So you have the stick as an paired devices under Bluetooth devices in the phone?
Is this the only paired device you have?
Check if it is possible to reset the selfie stick some how and try again and if its still not working you may want to try this selfie stick with another phone to confirm if it could be a problem with it.
Try removing the other paired devices in your Bluetooth list. They may be interfering with the connection to your selfie stick.
Otherwise I'm afraid I have no other suggestion since the phone seems to be working fine with other Bluetooth devices. What you could do is to check with the manufacturer of the stick which phones that are listed as compatible devices.
Anyone found any solution for this.
I think smart connect app is causing the issue.
I can open the camera with smart connect after connecting the selfie stick remote.
But clicking the remote button only reponing the camera.
Hi
am uising sone xerpia T3 and trying to connect selfie stick its not connecting . when open camera and click the selfie stick button it zooming and taking picture.. please let me know how to fix the issue
Shutter button on selfie sticks is like pressing a volume up or down button on your phone. Xperia phones have a dedicated CAMERA button on the phone, which you would have to have assigned to the shutter button on the stick. Volume up and down zoom in on the Camera app, which is why your stick is doing that.
Anybody able to find a selfie stick that works with Xperia phones?
