Hey Guys..
i am reltively new with the x 10
Mine is just 2 months old And recently updated it to 2.1
But mediascape doesnt still have a option of selecting multiple files over bluetooth....
and i am still adding contacts to the senders list for an sms individually throught he addrecipients or edit recipients option...isnt there an option to mark recievers at one go as in normal phones..
please help this gives a big headache while sending sms to many people .......i am currently using handscent sms but wanted to know if sony did provide a bug fix for th same,,,
You can also use Bluetooth File Transfer to send several files via Bluetooth. It is free from the Market and pretty good.
Haha yeah I know it's a pain, and you have to play the song so you could send it.. It's because Mediascape wasn't mainly designed for such actions; It's nothing more than going in and enjoying your media files.
I have found a great solution though! There's this amazing App in the Market called: "File Manager" it has a white folder as a logo; You could multi-select your media files, delete them, send them, anything you want, i'm satisfied with it.
As for the SMS issue, there's no solution apparently yet.. You will have to select the recipients individually.
I hope SE come up with a solution, maybe in the Multi-touch update coming in Q1 of 2011, because in the Android 2.1 update they have made many improvements.
Good Luck
Yeah I have that too :smileygrin:
by the way they have given the feature of sending multiple files whenever we use the facebook app to upload photos ..a very nice ui comes up on the screen and all u to select multiple files and send them here......this feature is present in all the applications in which u need to select photos from the gallery .... really silly of xperia development team!!!!!!
by the way are there anyhopes on the upgrade to 2.2?
