Hi I had an update 2 weeks and ago and since then my Google Chrome has stopped working the error message i get is "unfortunately, chrome has stopped" "report or ok"
Has anyone else had the same problem
Have you tried settings-apps-all-chrome,force stop and clear data?
Hi Thank you will give t a go
Keep us updated.
Unfortunately that has not worked, still doing the same
Fantastic, Thank you very much for your help, it is now fully working
Anytime.
Hi. This was very useful imformation and solved the issue of Chrome not responding. After having my Z2 handset for 4 days, suddenly last night Chrome very annoyingly decided to stop working.
I got the box out looking for warranty etc but there is nothing there so after reading the support guide, I created an account here and now my problem is fixed.
Happy. Thank you.
Great.
